# Page Not Found
The URL `gw-examples/mqtt+aws-iot-core` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [MQTT+AWS IoT Core](https://docs.ruuvi.com/ruuvi-gateway-firmware/examples/mqtt+aws-iot-core.md)
- [MQTT examples](https://docs.ruuvi.com/ruuvi-gateway-firmware/examples/mqtt-examples.md)
- [GW Install custom firmware](https://docs.ruuvi.com/ruuvi-gateway-firmware/gw-install-custom-firmware.md)
- [GW open ports / services](https://docs.ruuvi.com/ruuvi-gateway-firmware/gw-open-ports-services.md)
- [Home Assistant](https://docs.ruuvi.com/ruuvi-gateway-firmware/examples/home-assistant.md)
GET https://docs.ruuvi.com/ruuvi-gateway-firmware/examples/mqtt+aws-iot-core.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/ruuvi-gateway-firmware/examples/mqtt+aws-iot-core.md`).
