HTTP: Data from Bluetooth-sensors without timestamps
Relaying of accumulated Bluetooth data (without timestamps) to HTTP/HTTPS server.
The JSON data format description is provided in JSON schema format (https://json-schema.org), which provides clear human- and machine-readable documentation with examples.
The format of relayed messages is described here https://docs.ruuvi.com/communication/bluetooth-advertisements
"$id": "http://ruuvi.com/schemas/ruuvi_http_data_without_timestamps.schema.json",
"title": "Data from Bluetooth-sensors (without timestamps) relayed via HTTP/HTTPS",
"type": "object",
"required": [
"data"
"properties": {
"data": {
"title": "Data-object containing accumulated data from Bluetooth-sensors for relaying",
"type": "object",
"required": [
"nonce",
"gw_mac",
"tags"
"properties": {
"coordinates": {
"type": "string",
"default": "",
"title": "GPS-coordinates of Ruuvi Gateway (optional)",
"examples": [
"nonce": {
"type": "string",
"title": "Nonce - sequentially incremented number for each message, the initial value of which is set randomly",
"examples": [
"2636366621"
"gw_mac": {
"type": "string",
"title": "MAC-address of Ruuvi Gateway",
"examples": [
"C8:25:2D:8E:9C:2C"
"tags": {
"type": "object",
"title": "Array of records with relayed messages from Bluetooth-sensors",
"items": {
"type": "object",
"patternProperties": {
"^([0-9A-Fa-f]{2}[:-]){5}([0-9A-Fa-f]{2})$": {
"type": "object",
"title": "MAC-address of Bluetooth-sensor",
"required": [
"rssi",
"counter",
"data"
"properties": {
"rssi": {
"type": "integer",
"title": "RSSI",
"examples": [
-71
"counter": {
"type": "string",
"title": "Counter of messages from Bluetooth-sensors that were received by Gateway",
"examples": [
"363"
"data": {
"type": "string",
"title": "Relayed message from Bluetooth-sensor in hex encoding",
"examples": [
"0201061BFF99040513C85714C7CC00240008041CAB76F41C3CC6A5B9E0AD06"
"minItems": 0,
"uniqueItems": true
"examples": [
"data": {
"coordinates": "",
"nonce": "2896361039",
"gw_mac": "C8:25:2D:8E:9C:2C",
"tags": {
"E3:75:CF:37:4E:23": {
"rssi": -50,
"counter": "363",
"data": "0201061BFF990405158A5B05C6810004004403DCAB767A45BDE375CF374E23"
"F4:1F:0C:28:CB:D6": {
"rssi": -32,
"counter": "365",
"data": "0201061BFF990405166455D5C6DD0008FFF803F0ADB60F2A92F41F0C28CBD6"
PreviousHTTP: Time-stamped data from Bluetooth-sensors
NextMQTT: Time-stamped data from Bluetooth-sensors
Last updated
