LogoLogo
⌘Ctrlk
LogoLogo
  • Ruuvi Developer Documentation
    • RuuviTag B
    • RuuviTag Pro
    • Ruuvi Air
    • Ruuvi Gateway
    • Ruuvi DevShield
    • TMP 117 External Sensor
    • Ruuvi Connector System
    • 1.2.12
    • 2.5.9
    • 3.X
    • Device Firmware Update (DFU)
    • Air 1st Stage Bootloader
    • Air 2nd Stage Bootloader
    • Air Firmware Loader
    • Air Main Firmware
    • Ruuvi Indoor Air Quality Score (IAQS)
    • GW Getting Started
    • GW Web-UI
    • GW nRF52811 Firmware
    • GW ESP32 Firmware
    • GW Data formats
      • HTTP: Time-stamped data from Bluetooth-sensors
      • HTTP: Data from Bluetooth-sensors without timestamps
      • MQTT: Time-stamped data from Bluetooth-sensors
      • MQTT: Data from Bluetooth-sensors without timestamps
      • HTTP GET /history (with timestamps) and decoding
      • HTTP: Gateway status
      • Gateway configuration
    • GW Examples
    • GW open ports / services
    • GW Install custom firmware
    • Bluetooth advertisements
    • Bluetooth connection
    • Real Time Transfer (RTT)
    • Ruuvi Cloud
    • Integrations
Powered by GitBook
For the complete documentation index, see llms.txt. This page is also available as Markdown.
  1. Ruuvi Gateway Firmware
GW Data formats
This page contains descriptions of the data formats that are used when communicating with Ruuvi gateway.
HTTP: Time-stamped data from Bluetooth-sensorsHTTP: Data from Bluetooth-sensors without timestampsMQTT: Time-stamped data from Bluetooth-sensorsMQTT: Data from Bluetooth-sensors without timestampsHTTP GET /history (with timestamps) and decodingHTTP: Gateway statusGateway configuration
PreviousGW ESP32 MQTT client
NextHTTP: Time-stamped data from Bluetooth-sensors
Last updated 3 years ago
