Skip to content
For the complete documentation index, see llms.txt. This page is also available as Markdown.
Backend: MQTT(s)
You can configure relaying data to MQTT server:
You can choose the data format - raw data received from Bluetooth sensors or decoded data for Ruuvi sensors:
By default, data received from Bluetooth sensors is retransmitted over MQTT immediately, but if you have a lot of sensors you may want to limit the data flow. In order to do this you can set a sending interval:
It also supports MQTT client authentication via SSL by enabling the upload of a client certificate and its associated private key, ensuring secure and verified client-server communication. You can use a server SSL Certificate if you want to be independent of public Certificate Authorities (CAs) or if you have deployed a self-signed certificate on the HTTPS server, giving you greater control and customization over your security infrastructure:
Last updated
