Skip to content
For the complete documentation index, see llms.txt. This page is also available as Markdown.
GW open ports / services
Lifecycle: in production
Ruuvi Gateway uses the following network services and ports.
DHCP
  • 67/udp inbound — DHCP server in configuration hotspot mode (unconfigured / after Configure button).
  • 68/udp outbound — DHCP client when Ethernet/Wi‑Fi uses DHCP.
DNS
  • 5353/udp bi‑directional — mDNS on LAN (gateway discoverable via its *.local name).
  • 53/udp, 53/tcp outbound — Unicast DNS to configured resolvers (required to resolve Ruuvi Cloud and any user‑configured endpoints).
HTTP(S)
  • 80/tcp inbound — Web UI & local APIs over LAN (/, /history, /metrics, /ruuvi.json).
    • Sensitive configuration fields are encrypted during hotspot provisioning. Local HTTP is plaintext; place the device on a trusted LAN or use a reverse proxy/TLS terminator if HTTPS on LAN is required.
  • 443/tcp outbound — HTTPS to cloud/update services: network.ruuvi.com, fwupdate.ruuvi.com. Allowing *.ruuvi.com is recommended.
MQTT(S) (optional)
  • 1883/tcp outbound — MQTT to user‑configured broker (disabled by default).
  • 8883/tcp outbound — MQTT over TLS to user‑configured broker (disabled by default).
NTP
  • 123/udp outbound — Time sync. DHCP‑provided NTP servers are supported.
    • Common defaults: time.ruuvi.com, time.google.com, time.cloudflare.com, pool.ntp.org (may vary by firmware).
Last updated
