For the complete documentation index, see llms.txt. This page is also available as Markdown.
Firmware update via API
You can run a firmware update from a specified URL programmatically, using bearer authentication.
On the "Access Settings" page, enable full access using bearer authentication and set the API-key:
Example of a command to run a firmware update from the URL: "https://my_server.com:7000/gw_firmware/"
Last updated
