# Page Not Found
The URL `ruuvi-hardware/ruuvi-connector-kit` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Ruuvi Connector System](https://docs.ruuvi.com/ruuvi-hardware/ruuvi-connector-system.md)
- [Ruuvi Connector Kit](https://docs.ruuvi.com/ruuvi-hardware/ruuvi-connector-system/ruuvi-connector-kit.md)
- [Connectors](https://docs.ruuvi.com/ruuvi-hardware/ruuvi-connector-system/connectors.md)
- [Ruuvi Air](https://docs.ruuvi.com/ruuvi-hardware/ruuvi-air.md)
- [Ruuvi Gateway](https://docs.ruuvi.com/ruuvi-hardware/ruuvi-gateway.md)
GET https://docs.ruuvi.com/ruuvi-hardware/ruuvi-connector-system.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/ruuvi-hardware/ruuvi-connector-system.md`).
