> For the complete documentation index, see [llms.txt](https://docs.ruuvi.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ruuvi.com/ruuvi-gateway-firmware/examples/configuration-download-from-a-remote-server-via-api.md).
# Configuration download from a remote server via API
You can trigger a forced configuration download programmatically, using bearer authentication, but you must first configure the Gateway to use [Automatic configuration download](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/automatic-configuration-download.md).
Configuration on the remote server must contain the field **lan\_auth\_api\_key\_rw**:
```json
  "remote_cfg_use": true,
  "remote_cfg_url": "http://192.168.1.101:7000/",
  "remote_cfg_refresh_interval_minutes": 10,
  "remote_cfg_auth_type": "no",
  "lan_auth_api_key_rw": "1SDrQH1FkH+pON0GsSjt2gYeMSP02uYqfuu7LWdaBvY="
Example of a command to trigger a configuration download from the preconfigured remote server:
curl -v http://<RUUVI_GW_IP>/gw_cfg_download
    -H "Authorization: Bearer 1SDrQH1FkH+pON0GsSjt2gYeMSP02uYqfuu7LWdaBvY=" -d ''
