> For the complete documentation index, see [llms.txt](https://docs.ruuvi.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages.md).
# GW Web-UI
## User interface
Ruuvi Gateway sets up a WiFi hotspot and a webserver that provides the user interface for configuration over HTTP. The user interface can be accessed in any major browser. To connect to the user interface connect to the hotspot "**Configure Ruuvi Gateway XXXX**" (it does not require a password). Once connected, open your browser and enter **<http://10.10.0.1>** . After the initial configuration is complete, you will be able to access the gateway from the LAN in the same way.
* [Greeting window](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/greeting-window.md)
* [Internet connection settings](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/internet-connection-settings.md)
  * [Connection via Wi-Fi](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/internet-connection-settings/connection-via-wi-fi.md)
  * [Connection via Ethernet](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/internet-connection-settings/connection-via-ethernet.md)
* [Software update](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/software-update.md)
* [Automatic configuration download](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/automatic-configuration-download.md)
* [Automatic updates](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/automatic-updates.md)
* [Access Settings from LAN](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/access-settings-from-lan.md)
* [Cloud Options](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/cloud-options.md)
  * [Backend: HTTP(s)](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/cloud-options/backend-http-s.md)
  * [Backend: MQTT(s)](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/cloud-options/backend-mqtt-s.md)
  * [Backend: Statistics](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/cloud-options/backend-statistics.md)
* [Time Synchronisation Options](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/time-synchronisation-options.md)
* [Bluetooth Scanning Settings](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/bluetooth-scanning-settings.md)
* [Configuration completion](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/configuration-completion.md)
* [Authentication when accessing from LAN](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/auth.html.md)
