For the complete documentation index, see llms.txt. This page is also available as Markdown.
Connection via Wi-Fi
Select the desired Wi-Fi and enter the password:
If your router supports WPS (Wi-Fi Protected Setup), you can connect to a Wi-Fi hotspot without entering a password. Enable the checkbox "Use WPS to connect to Wi-Fi network", press the "Next" button and then press the WPS button on your router.
In case Wi-Fi is hidden, you can enter WiFi SSID manually - this option is available under "Advanced settings":
Last updated
