MQTT: Data from Bluetooth-sensors without timestamps
Immediate relaying of Bluetooth data (without timestamps) to MQTT server.
The JSON data format description is provided in JSON schema format (https://json-schema.org), which provides clear human- and machine-readable documentation with examples.
The format of relayed messages is described here https://docs.ruuvi.com/communication/bluetooth-advertisements
"$id": "http://ruuvi.com/schemas/ruuvi_mqtt_data_without_timestamps.schema.json",
"title": "Data from Bluetooth-sensors (without timestamps) relayed via MQTT",
"type": "object",
"required": [
"data"
"properties": {
"gw_mac": {
"title": "MAC-address of Ruuvi Gateway",
"type": "string",
"pattern": "^([0-9A-Fa-f]{2}[:-]){5}([0-9A-Fa-f]{2})$",
"examples": [
"C8:25:2D:8E:9C:2C"
"rssi": {
"title": "RSSI",
"type": "integer",
"examples": [
-26
"aoa": {
"title": "???",
"type": "array",
"default": [],
"items": {},
"examples": [
"cnt": {
"title": "Counter of messages from Bluetooth-sensors that were received by Gateway",
"type": "string",
"examples": [
"338"
"data": {
"title": "Relayed message from Bluetooth-sensor in hex encoding",
"type": "string",
"examples": [
"0201061BFF99040515AE4C6DC6D7000CFFF803F4ADB6AD697FF41F0C28CBD6"
"coords": {
"title": "GPS-coordinates of Ruuvi Gateway (optional)",
"type": "string",
"examples": [
"examples": [
"gw_mac": "C8:25:2D:8E:9C:2C",
"rssi": -25,
"aoa": [],
"cnt": "338",
"data": "0201061BFF990405166455D5C6DE0008FFF403F0AE760F2A8BF41F0C28CBD6",
"coords": ""
PreviousMQTT: Time-stamped data from Bluetooth-sensors
NextHTTP GET /history (with timestamps) and decoding
Last updated
