# Page Not Found
The URL `ruuvi-station-app/use-with-ruuvi-gateway-ruuvi-network` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Ruuvi Gateway](https://docs.ruuvi.com/ruuvi-hardware/ruuvi-gateway.md)
- [GW Web-UI](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages.md)
- [Ruuvi Air](https://docs.ruuvi.com/ruuvi-hardware/ruuvi-air.md)
- [Ruuvi DevShield](https://docs.ruuvi.com/ruuvi-hardware/ruuvi-devshield.md)
- [RuuviTag Pro](https://docs.ruuvi.com/ruuvi-hardware/ruuvitag-pro.md)
Perform an HTTP GET request on the following URL with the `ask` and `goal` query parameters:
GET https://docs.ruuvi.com/ruuvi-hardware/ruuvi-gateway.md?ask=<question>&goal=<user_goal>
`goal` is what the user is ultimately trying to achieve, the reason they need the answer. Sharing it helps GitBook give you a better, more relevant answer. A goal is most helpful when it describes the outcome the user wants rather than restating the question. For example, with `ask=how do I create an API token`, a goal like `automate deployments from our CI pipeline` lets GitBook tailor the answer to that use case.
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/ruuvi-hardware/ruuvi-gateway.md`).
