# Page Not Found
The URL `ruuvi-gateway-firmware/gateway-web-ui` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [GW Web-UI](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages.md)
- [GW Examples](https://docs.ruuvi.com/ruuvi-gateway-firmware/examples.md)
- [GW Data formats](https://docs.ruuvi.com/ruuvi-gateway-firmware/data-formats.md)
- [GW ESP32 Firmware](https://docs.ruuvi.com/ruuvi-gateway-firmware/gw-esp32-firmware.md)
- [GW Getting Started](https://docs.ruuvi.com/ruuvi-gateway-firmware/gw-getting-started.md)
GET https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/ruuvi-gateway-firmware/gateway-html-pages.md`).
