# Page Not Found
The URL `ruuvi-gateway-firmware/gateway-web-ui/internet-connection-settings/connection-via-ethernet` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Connection via Ethernet](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/internet-connection-settings/connection-via-ethernet.md)
- [Connection via Wi-Fi](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/internet-connection-settings/connection-via-wi-fi.md)
- [Internet connection settings](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/internet-connection-settings.md)
- [Bluetooth Scanning Settings](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/bluetooth-scanning-settings.md)
- [Configuration completion](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/configuration-completion.md)
GET https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/internet-connection-settings/connection-via-ethernet.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/ruuvi-gateway-firmware/gateway-html-pages/internet-connection-settings/connection-via-ethernet.md`).
