# Page Not Found
The URL `ruuvi-gateway-firmware/gateway-web-ui/software-update` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Software update](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/software-update.md)
- [Automatic updates](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/automatic-updates.md)
- [Firmware update via API](https://docs.ruuvi.com/ruuvi-gateway-firmware/examples/firmware-update-via-api.md)
- [GW Web-UI](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages.md)
- [Configuration completion](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/configuration-completion.md)
GET https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/software-update.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/ruuvi-gateway-firmware/gateway-html-pages/software-update.md`).
