# Page Not Found
The URL `gw-examples/poll-endpoint-metrics` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Poll endpoint "/metrics"](https://docs.ruuvi.com/ruuvi-gateway-firmware/examples/poll-endpoint-metrics.md)
- [GW open ports / services](https://docs.ruuvi.com/ruuvi-gateway-firmware/gw-open-ports-services.md)
- [Polling mode](https://docs.ruuvi.com/ruuvi-gateway-firmware/examples/polling-mode.md)
- [Ruuvi Indoor Air Quality Score (IAQS)](https://docs.ruuvi.com/ruuvi-air-firmware/ruuvi-indoor-air-quality-score-iaqs.md)
- [Bluetooth Scanning Settings](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/bluetooth-scanning-settings.md)
GET https://docs.ruuvi.com/ruuvi-gateway-firmware/examples/poll-endpoint-metrics.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/ruuvi-gateway-firmware/examples/poll-endpoint-metrics.md`).
