# Page Not Found
The URL `ruuvi-gateway-firmware/gateway-web-ui/bluetooth-scanning-settings` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Bluetooth Scanning Settings](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/bluetooth-scanning-settings.md)
- [Internet connection settings](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/internet-connection-settings.md)
- [Greeting window](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/greeting-window.md)
- [Automatic updates](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/automatic-updates.md)
- [Access Settings from LAN](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/access-settings-from-lan.md)
GET https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/bluetooth-scanning-settings.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/ruuvi-gateway-firmware/gateway-html-pages/bluetooth-scanning-settings.md`).
