# Page Not Found
The URL `gw-data-formats` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [GW Data formats](https://docs.ruuvi.com/ruuvi-gateway-firmware/data-formats.md)
- [GW ESP32 Firmware](https://docs.ruuvi.com/ruuvi-gateway-firmware/gw-esp32-firmware.md)
- [GW nRF52811 Firmware](https://docs.ruuvi.com/ruuvi-gateway-firmware/gw-nrf52-firmware.md)
- [GW Getting Started](https://docs.ruuvi.com/ruuvi-gateway-firmware/gw-getting-started.md)
- [GW Install custom firmware](https://docs.ruuvi.com/ruuvi-gateway-firmware/gw-install-custom-firmware.md)
GET https://docs.ruuvi.com/ruuvi-gateway-firmware/data-formats.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/ruuvi-gateway-firmware/data-formats.md`).
