# Page Not Found
The URL `ruuvi-gateway-firmware/gateway-web-ui/time-synchronisation-options` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Time Synchronisation Options](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/time-synchronisation-options.md)
- [Cloud Options](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/cloud-options.md)
- [Automatic configuration download](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/automatic-configuration-download.md)
- [Configuration completion](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/configuration-completion.md)
- [Internet connection settings](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/internet-connection-settings.md)
GET https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/time-synchronisation-options.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/ruuvi-gateway-firmware/gateway-html-pages/time-synchronisation-options.md`).
