# Page Not Found
The URL `gw-data-formats/http-data-from-bluetooth-sensors-without-timestamps` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [HTTP: Data from Bluetooth-sensors without timestamps](https://docs.ruuvi.com/ruuvi-gateway-firmware/data-formats/http-data-from-bluetooth-sensors-without-timestamps.md)
- [MQTT: Data from Bluetooth-sensors without timestamps](https://docs.ruuvi.com/ruuvi-gateway-firmware/data-formats/mqtt-data-from-bluetooth-sensors-without-timestamps.md)
- [HTTP: Time-stamped data from Bluetooth-sensors](https://docs.ruuvi.com/ruuvi-gateway-firmware/data-formats/http-time-stamped-data-from-bluetooth-sensors.md)
- [MQTT: Time-stamped data from Bluetooth-sensors](https://docs.ruuvi.com/ruuvi-gateway-firmware/data-formats/mqtt-time-stamped-data-from-bluetooth-sensors.md)
- [HTTP GET /history (with timestamps) and decoding](https://docs.ruuvi.com/ruuvi-gateway-firmware/data-formats/http-get-history-with-timestamps-and-decoding.md)
GET https://docs.ruuvi.com/ruuvi-gateway-firmware/data-formats/http-data-from-bluetooth-sensors-without-timestamps.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/ruuvi-gateway-firmware/data-formats/http-data-from-bluetooth-sensors-without-timestamps.md`).
