> For the complete documentation index, see [llms.txt](https://docs.ruuvi.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/cloud-options/backend-http-s.md).
# Backend: HTTP(s)
You can enable or disable sending data to Ruuvi Cloud:
<figure><img src="/files/O3LY1N5ymb5sF7PmP8xo" alt=""><figcaption></figcaption></figure>
Or configure to send data to your own server via HTTP/HTTPS (it is possible to send data to both destinations, Ruuvi Cloud and your own server, at the same time):
<figure><img src="/files/IS47BqjPVAPJ5jYWvxKQ" alt=""><figcaption></figcaption></figure>
For your own server, you can choose the data format and decode data from Ruuvi sensors on the Gateway side:
<figure><img src="/files/UeUn8asAfvwEVxVhQHel" alt=""><figcaption></figcaption></figure>
Configure sending interval:
<figure><img src="/files/tMAod1Ikj7nMjoBJ9RJ0" alt=""><figcaption></figcaption></figure>
### Use different types of authentication
#### Configuring Basic Authentication
When using "Basic" authentication, the gateway adds an authorization header to the HTTPS request. This header contains the credentials encoded in Base64 format.
<figure><img src="/files/z5f2aU3ZSvTKNZ2VXTic" alt=""><figcaption></figcaption></figure>
HTTP Header Example:\
`Authorization: Basic dXNlcjE6cGFzczE=`
Explanation:
* `Basic`: Indicates the authentication method.
* `dXNlcjE6cGFzczE=`: Base64 encoded credentials. For example, 'user1:pass1' encodes to 'dXNlcjE6cGFzczE='.
#### Configuring Bearer Authentication
When using "Bearer" authentication, the gateway adds an authorization header with a token to the HTTPS request. This token is a credential used to access APIs securely.
<figure><img src="/files/hGjfnUarYGSaM1TmaEdP" alt=""><figcaption></figcaption></figure>
`Authorization: Bearer token123`
#### Configuring Token-Based Authentication
Token-based authentication involves securing API requests by sending a token in the HTTP header. The token is a unique identifier that must be included in every request.
<figure><img src="/files/tPuMs1tt9ZPQO0ixEOxp" alt=""><figcaption></figcaption></figure>
`Authorization: Token token124`
#### Configuring API Key Authentication
API key authentication is a simple method where an API key is used directly as part of the HTTP header to authenticate requests.
<figure><img src="/files/d7O1huyTzRxVc7TgHc86" alt=""><figcaption></figcaption></figure>
`Authorization: token125`
#### Enhanced Security with SSL Client Authentication
It also supports client authentication via SSL by enabling the upload of a client certificate and its associated private key, ensuring secure and verified client-server communication:
<figure><img src="/files/Rb07ISiKaZTce0a4gXTf" alt=""><figcaption></figcaption></figure>
You can use a server SSL Certificate if you want to be independent of public Certificate Authorities (CAs) or if you have deployed a self-signed certificate on the HTTPS server, giving you greater control and customization over your security infrastructure:
<figure><img src="/files/TcuM5fVF0UXEYkOz0272" alt=""><figcaption></figcaption></figure>
