> For the complete documentation index, see [llms.txt](https://docs.ruuvi.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ruuvi.com/ruuvi-firmware/device-firmware-update-dfu.md).
# Device Firmware Update (DFU)
There are two different options on how to update RuuviTag firmware.
### OTA (Over the Air)
### **Ruuvi firmware version 1.x, 2.x**
Ruuvitag firmware version up until 2.x are built on top of Nordic SDK 12.3 / Softdevice s132 v3.1.1. The bootloader on these RuuviTags uses debug-mode which skips hardware and firmware version checks.
The keyfile to sign the RuuviTag updates is published in [ruuvitag\_fw](https://github.com/ruuvi/ruuvitag_fw/tree/master/keys) repository.
| Command to generate DFU package for RuuviTags up to firmware version 2        |
| `nrfutil pkg generate --debug-mode --application _build/ruuvi_firmware.hex --hw-version 3 --sd-req 0x91 --key-file ~/git/ruuvitag_fw/keys/ruuvi_open_private.pem ruuvi_firmware_dfu.zip` |
To upload package to RuuviTag, press button "B" and tap "R" to reset the tag. Bootloader checks if button "B" is pressed at boot and enters the bootloader mode.
### **Ruuvi firmware version 3.x**
Ruuvi firmware 3 builds on SDK15.3 and Softdevice s132 v6.1.1. There are special edition RuuviTags with nRF52811 that do not have bootloader at all due to size constraints.
The bootloader is a production version and it enforces version checks. On RuuviTag B1 ... B7.1 the hardware version is 0xB0, regardless of which sensors are installed.
| Command to generate DFU package for RuuviTags with firmware version 3        |
| `nrfutil pkg generate --application _build/nrf52832_xxaa.hex --application-version 1 --hw-version 0xB0 --sd-req 0xB7 --key-file ruuvi_open_private.pem ${BINNAME}_dfu_app.zip` |
In bootloader mode the tag advertises itself with name "RuuviBoot" and it provides [BLE DFU Service](https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v12.3.0/group__nrf__ble__dfu.html?cp=7_5_8_6_8_4_0). Nordic Semiconductor provides libraries for [iOS](https://github.com/NordicSemiconductor/IOS-Pods-DFU-Library) and [Android](https://github.com/NordicSemiconductor/Android-DFU-Library) to interface with the service.
### SWD (Serial Wire Debug)
If you're developing your own firmware or need to flash hunderds or more of RuuviTags, you should consider using a wired programmer for higher programming speed. To create your own hex image for flashing, you need 4 parts:
* Softdevice
* Bootloader
* Bootloader settings
* Application
The softdevice is given by Nordic Semiconductor or other company which provides the radio protocol.
You can use Ruuvi's bootloader available at <https://github.com/ruuvi/ruuvi.nrf5_sdk15_bootloader.c>, but you should at least change the public key used for verifying the firmware images to ensure that you can keep the full control of your tags.
Settings are generated with nrfutil, which is part of [Nordic Command Line Tools](https://www.nordicsemi.com/Software-and-tools/Development-Tools/nRF-Command-Line-Tools). You'll also need nrfjprog and mergehex from the command line tool package.
Application is the .hex file you have created.
| Commands to generate application settings and merge them into one package        |
| `nrfutil settings generate --family NRF52 --application _build/nrf52832_xxaa.hex --application-version 1 --bootloader-version 1 --bl-settings-version 1 settings.hex` |
| `mergehex -m ../../../../nRF5_SDK_15.3.0_59ac345/components/softdevice/s132/hex/s132_nrf52_6.1.1_softdevice.hex $BOOTLOADER settings.hex -o sbc.hex`                  |
| `mergehex -m sbc.hex _build/nrf52832_xxaa.hex -o packet.hex`        |
| Commands to flash the package to RuuviTag |
| `nrfjprog --eraseall`                     |
| `nrfjprog --program packet.hex`           |
| `nrfjprog --reset`                        |
If your firmware is secret or you wish to avoid duplications by users, you should enable the read protection bit .
`nrfjprog -f nrf52 --rbp ALL`
If you have enabled the read protection, you must run `nrfjprog --recover` to use the programming interface again. This completely erases the tag.
**Always power cycle the tag after using a wired programmer. Otherwise the debug interface might remain active and consume excess current.**
