# Page Not Found
The URL `ruuvi-connector-system` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Ruuvi Connector System](https://docs.ruuvi.com/ruuvi-hardware/ruuvi-connector-system.md)
- [Ruuvi Connector Kit](https://docs.ruuvi.com/ruuvi-hardware/ruuvi-connector-system/ruuvi-connector-kit.md)
- [Connectors](https://docs.ruuvi.com/ruuvi-hardware/ruuvi-connector-system/connectors.md)
- [Cables](https://docs.ruuvi.com/ruuvi-hardware/ruuvi-connector-system/cables.md)
- [Expansion boards](https://docs.ruuvi.com/ruuvi-hardware/ruuvi-connector-system/expansion-boards.md)
Perform an HTTP GET request on the following URL with the `ask` and `goal` query parameters:
GET https://docs.ruuvi.com/ruuvi-hardware/ruuvi-connector-system.md?ask=<question>&goal=<user_goal>
`goal` is what the user is ultimately trying to achieve, the reason they need the answer. Sharing it helps GitBook give you a better, more relevant answer. A goal is most helpful when it describes the outcome the user wants rather than restating the question. For example, with `ask=how do I create an API token`, a goal like `automate deployments from our CI pipeline` lets GitBook tailor the answer to that use case.
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/ruuvi-hardware/ruuvi-connector-system.md`).
