# Page Not Found
The URL `ruuvi-gateway-firmware/gateway-web-ui/automatic-updates` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Automatic updates](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/automatic-updates.md)
- [Software update](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/software-update.md)
- [Automatic configuration download](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/automatic-configuration-download.md)
- [GW Web-UI](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages.md)
- [Authentication when accessing from LAN](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/auth.html.md)
GET https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/automatic-updates.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/ruuvi-gateway-firmware/gateway-html-pages/automatic-updates.md`).
