# Page Not Found
The URL `gw-examples/firmware-update-via-api` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Firmware update via API](https://docs.ruuvi.com/ruuvi-gateway-firmware/examples/firmware-update-via-api.md)
- [Configuration update via API](https://docs.ruuvi.com/ruuvi-gateway-firmware/examples/configuration-update-via-api.md)
- [Device Firmware Update (DFU)](https://docs.ruuvi.com/ruuvi-firmware/device-firmware-update-dfu.md)
- [Configuration download from a remote server via API](https://docs.ruuvi.com/ruuvi-gateway-firmware/examples/configuration-download-from-a-remote-server-via-api.md)
- [Software update](https://docs.ruuvi.com/ruuvi-gateway-firmware/gateway-html-pages/software-update.md)
Perform an HTTP GET request on the documentation index with the `ask` parameter:
GET https://docs.ruuvi.com/ruuvi-gateway-firmware/examples/firmware-update-via-api.md?ask=<question>
The question should be specific, self-contained, and written in natural language.
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/ruuvi-gateway-firmware/examples/firmware-update-via-api.md`).
